Upgraded to Quartus Pro 22.1: "No key to decrypt data block" error for Low Latency 100G Ethernet
- 4 years ago
We managed to resolve this problem, and it turned out it wasn't a licensing issue.
The issue was that IP upgrade tool from Quartus Pro 19.2 to 22.1 didn't work. Presumably the tool left behind Verilog that was encrypted with the keys of 19.2. Deleting the IP core from the design and adding a new IP core from 22.1 with the same configuration parameters did achieve a design that built successfully.
Hi Simon Moore,
I'm glad that you been able to resolve the issue. Its always recommended to add a new IP core instead of using the old IP core as it might have some complication when the version has been upgraded.
Since the issue has been resolved, I now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
Pavee
