8 years agoUpgrade IP (t)error, when using two (different) instances of the LPM_compare
For a circuit that includes two LPM_compare components generated by the MegaWizard, I suddenly get the ip upgrade required prompted. However, when I launch the IP Upgrade Tool, then only one of th...
8 years agoHi,
No matter how many instances of an IP you have, the IP upgrade tool will have to upgrade only the main IP component. This will reflect throughout the design where ever the same IP is instanced again. You may want to close and restart Quartus tool after the IP upgrade and check again.
