8 years agoUpdating Block or Symbol File from HDL
Hi, Is there a way to update the pins on an existing symbol or update the I/O table in an existing block from a VHDL file? Here's what I'm trying to do: I have a top level block diagram wi...
8 years agoUnfortunately that destroys any symbol customization I have made. I typically just end up adding or removing ports. I thought there might be a way to update the symbol (add/remove pins) from HDL. I guess that's not possible.
