hueslei
4 years agoUpdate Cyclone III to Cyclone 10
I need update my Cyclone II to Cyclone 10, but when I try compile the code, Quartus return error message below:
" Error (292019): IP core Nios II Processor (6AF7_00A2) not supported in dev...
ak6dn
4 years agoThe error message is pretty obvious and explicit. Your existing project on the Cyclone II uses a specific Nios II processor IP core.
In the new device you select, the Cyclone 10 LP, that Nios II processor core you are using is NOT supported.
So you can't just change the device family, change the Quartus version, and recompile your existing design.
You have to replace the Nios II core with a supported/updated Nios II core on your new device (Cyclone 10 LP).
hueslei
4 years agoMaybe it's obvius to you!!
I asked it because I know others example they performed procedure exactly like me and the project compile without problems.
Anyway, thanks for your comment.
