15 years agoBecause the FIR output looks correct (except for a possible offset), it seems clear that the above internal signal has a wrong display format.
The reason for the apparent offset is still unclear to me. Would you mind to post a quartus archive (*.qar file) of the full test design, including filter parameters and signal tap definition?
