CFlor36
6 years agoUnused PIN setting
during a fitter, is it possible to set some unused pins with the setting "RESERVED_INPUT" and others with the setting "RESERVED_INPUT_WITH_WEAK_PULLUP" ?
Florent
sstrell
6 years agoYes, in the Pin Planner or the Assignment Editor, you can make reserved pin assignments for individual pins, as opposed to the global setting in the Device and Pin Options. Just use the Reserved Pin assignment.
