14 years agoHello,
thank you for your answer. As I said before, the FIFO example is just an illustration. I am interested in this issue for every possible usage of the memory blocks. Correct if I am wrong : whatever the type of memory block, and whatever the block configuration (simple port memory / dual port memory / FIFO /...), if do not use the entire block, addresses left are lost ? There is not any optimization option that can allocate free space to other instances ? even with restrictions ? Thank you for your answer. Cecile
