15 years ago --- Quote Start --- is there a way fix the unsafe behavior in the above code? --- Quote End --- You should find an alternative way to achieve the intended behaviour. Actually I don't undertstand the meaning of the present code, e.g. three different cases of reset. Finding a synchronous solution would be preferable, of course.
