10 years agoUnrecognized command line option '-mno-hw-div' when compiling AOCL kernel
Hello, I am getting this error on every OpenCL kernel I am trying to compile, even those I have successfully compiled before on my machine. I have tried it on both AOCL 14.0 and 15.1. 201...
9 years agoAgreed. This is something that Intel/Altera should really look into, since it is such an obscure error that gives us absolutely no hint where to start looking at. Perhaps they've fixed on 17.0, but I have no access to this version. Problem solved (for now). Thank you everyone for the help!
--- Quote Start --- I can assure you this has nothing to do with the OS since I have been using CentOS v6.x since the beginning and I encountered this issue only once when I was using Quartus v15 on a cyclone board. The compiler also gives clear messages in the log when it crashes due to running out of memory; this case back then seemed like some issue with environmental variables to me. --- Quote End ---
