10 years agoUnrecognized command line option '-mno-hw-div' when compiling AOCL kernel
Hello, I am getting this error on every OpenCL kernel I am trying to compile, even those I have successfully compiled before on my machine. I have tried it on both AOCL 14.0 and 15.1. 201...
9 years agoI checked my old emails and the discussion I had with my colleague regarding this issue. I think the issue is the same as the one caused by X11 forwarding, just the error is different if you are targeting SoCs (you are targeting an SoC, right?). Try the suggestions from this topic (disable X11 forwarding and unset display):
https://www.alteraforum.com/forum/showthread.php?t=55328 Also avoid having multiple make files that call each other or export variables.
