Unpredictable Signaltap behavior (QPPro 20.2, Cyclone 10GX)
- 5 years ago
Is your design meeting timing? If you're failing timing, that could be causing the issue.
Check that you have selected the correct sampling clock and that it is functioning correctly (if possible).
Do you have any of the storage qualification features turned on? This could be the cause of missing samples from what you expect.
If you start the logic analyzer running again from this point (after it ran incorrectly the first time), does it run correctly for subsequent runs? I think you may be saying that subsequent runs do not work correctly until you recompile, but I wanted to clarify.
Can you show the configuration tab to see the trigger conditions and the configuration settings for the logic analyzer?
Do you able to solve the issue based on Sstrell's suggestion?
- NWein5 years ago
I've tweaked my timing constraints a bit, and it may or may not be fixed. Results are still inconclusive, but I should have a better idea in the next day or two. I will report back.
Neil
- NWein5 years ago
It does indeed look like it was timing related in the SignalPath logic. After adjusting my constraints things seem to be working more reliably.
If it starts breaking again I'll report back.
Neil
- gyuunyuu5 years ago
Contributor
Could you kindly specify how you were able to constrain the design to fix this problem?
