13 years agoI don't care about what ID they get, only that the IDs be distinct.
Are you sure that a function always returns a constant? When I use a function like "a <= f(b, c);" with signals a, b, c the result is clearly varying. I admit to never having tried "constant a := f(b, c);" with signals b, c. If it's syntactically correct, then I suppose it must be based on the initial values of the signal. So maybe your shared variable approach should work. Confused.
