ToddW
4 years agoUniphy Platform Designer Error: "Cannot find sequencer/sequencer.elf"
Prior to Quartus Prime Std v19, Intel used Cygwin for the Nios II Command Shell. Version 19.1 and beyond, they switched to using Ubunto 18.04 TLS and Windows Subsystem for Linux (WSL) to operate th...
ToddW
4 years agoI tried your proposed solution. I also have a space in my user account name. So I created a local name without spaces and tried re-running the project. No joy. Same result as before.
Intel engineering sent me a patch to try. It didn't work either. This is happening on two separate computers. Both have Ubuntu 18.04 and WLS v1 installed. Both successfully run Nios Command Shell from the Start menu.
I don't understand why this commonly reported error has not been successfully addressed for the past 3-4 years.
