ToddW
4 years agoUniphy Platform Designer Error: "Cannot find sequencer/sequencer.elf"
Prior to Quartus Prime Std v19, Intel used Cygwin for the Nios II Command Shell. Version 19.1 and beyond, they switched to using Ubunto 18.04 TLS and Windows Subsystem for Linux (WSL) to operate th...
MoZdk
4 years agoInstallation of WSL (Windows Subsystem for Linux) breaks the Quartus lite 18.1 Platform Designer so it is not possible to generate code with the DDR3 controller, even through WSL is not expected to be used for Quartus 18.1.
The error messages are similar to those given in Quartus 21.1 shown above.
When I disable WSL and restarts Windows, then the Quartus lite 18.1 Platform Designer can again generate code with the DDR3 controller.
