ToddW
4 years agoUniphy Platform Designer Error: "Cannot find sequencer/sequencer.elf"
Prior to Quartus Prime Std v19, Intel used Cygwin for the Nios II Command Shell. Version 19.1 and beyond, they switched to using Ubunto 18.04 TLS and Windows Subsystem for Linux (WSL) to operate th...
ToddW
4 years agoThank you for your response.
However, I have installed/removed/reinstalled Ubunto 18.04 and WSL while carefully following the instructions in the support article you mentioned as well as the more thorough Terasic article I mention above.
I am able to run Nios II Command Shell by itself from the Start menu. It recognizes typed commands as expected.
I have verified that the WSL is set to version 1.
I have verified the Environment variables are pointing to the correct locations:
- QUARTUS_ROOTDIR C:\intelFPGA\21.1\quartus
- QSYS_ROOTDIR C:\intelFPGA\21.1\quartus\sopc_builder\bin
- SOPC_KIT_NIOS2 C:\intelFPGA\21.1\nios2eds
I am still receiving the same errors as mentioned earlier.
Is there a means to interrupt the flow to just prior to the error occurring to see what the state of the machine is at that point?
