11 years agoThe behaviour is what you would expect in a functional simulation, but not according to hardware synthesis rules. They say you need an edge sensitive expression to infer a FF.
Compare with VHDL templates Positive edge register:-- Update the register output on the clock's rising edge
process (<clock_signal>)
begin
if (rising_edge(<clock_signal>)) then
<register_variable> <= <data>;
end if;
end process; Transparent latch -- Update the variable only when updates are enabled
process(<enable>, <data>)
begin
if (<enable> = '1') then
<latch_variable> <= <data>;
end if;
end process; The surprizing point is that (in this case) you get a FF (positive edge register) by omitting <data> from the sensitivity list. I would rather expect latch inference with a incomplete sensitivity list warning, as we get it in other cases.
