10 years agoUnconstrained output
First let me introduce my case, I simply used cyclone3 to communicate with a SSRAM, a 100MHZ clock coming into my FPGA ,which goes through a PLL and drives data out, the output of PLL i...
10 years agoIf you get negative slack on reset pin, you can resolve it using reset synchronizer and set_multicycle commands.
If you are sure that no clock transfer occurs between your incoming clock & the PLL output you can set_false_path between domains.
