11 years agoUnable to simulate ALTSQRT in ModelSim Altera
I wrote a small program to try out the altera sqrt ip. i included the module in a quick script i wrote, but when i try to simulate it, i get X values in some of the bit fields. I thought it might be ...
11 years ago --- Quote Start --- Hi Karthik, In a simulation when the X comes out from an IP block is when the IP cannot determined whether the output should be '0' or '1'. From the pic it seems your reset was not defined after the second clk cycle. Of course the output would be 'X' --- Quote End --- Hi, I tried that but didnt seem to change the result. its still driving the same output. The reset I've shown here is only for my logic which drives the input to the design. i dont even have any code that checks for that reset! also the reset itself isnt connected to the sqrt block.
