14 years agoUnable to regenerate BSP in Eclipse NIOS II EDS
Hello, I recently made a project in the NIOS II EDS version 11.1. In eclipse I made a BSP and an application to run with the BSP. Everything worked fine many times, but for some unkno...
11 years ago --- Quote Start --- Hi, could someone maybe clarify the solution above for me. I don't fully understand what do with the path-specification mentioned. In my simple mindedness I tried typing the entire thing in the windows command line ("run"-box), using the path to my own project directory of course... A black console appeared doing its thing briefly, so maybe I did it right... just don't know because it did not work... I'm working on a restricted faculty computer though, so maybe that's the problem. Reinstalling the program is really not possible either... A truly frustrating annoyance that the program simply can't remember where it created the project, when it all seems rather spelled out for it... --- Quote End --- regenerate a new BSP by right clicking on the bsp project and then go to nios II and generate bsp and then run your program as a hardware.
