NikunjTarsariya
4 years agoUnable to read FPGA Device-ID sometimes
Hi there,
We are using the Intel MAX10 FPGA and are programming the FPGA using the Altera-developed Jam STAPL file format. Although most of the time it works fine, we are facing issues sometime...
YuanLi_S_Intel
4 years agoI see. It sounds to me that it is due to issue in the jtagchain. Did you try to calibrate the delay on JAM? You may take a look at document below:
https://www.intel.com/programmable/technical-pdfs/654049.pdf
- NikunjTarsariya4 years ago
We have already calibrated delay so we are getting the correct Device-ID value every time except in failure cases. In failure cases, the same code is used but we are facing this issue intermittently over 100's AC cycle.
