Manikanta123
4 years agoUnable to read data from h2f_master port from HPS linux
Hai Team,
I'm using Agilex board and trying to interface Axi4Lite IP to HPS via h2f_master port and wrote small application in linux to read from h2f_master port but we are unable to read data ...
Manikanta123
4 years agoHai Jingyang,
Thanks for the reply. we tried as you suggested with above steps but the result is same i.e not showing any values in that address .
I checked after linux boot with devmem command also.
Here i attached the steps in u-boot console.
But the same flow is working fine in xilinx board ,i'm able read the data from that address .
Manikanta
