Unable to generate Transceiver IP for PCIe Gen6 PAM-4 64 GT/s rate on Intel Agilex-7 FPGA
Trying to generate the Transceiver IP on the Agilex-7 based FPGAs having FHT PMAs (also tried on FGT PMAs) with the support for PAM-4 64 GT/s rate to support PCIe Gen6. But not able to generate with the required configuration.
Are there specific steps to generate PAM-4 64 GT/s supported Transceiver?
- AR_A_Intel
Hi
To generate a Transceiver IP supporting PAM-4 64 GT/s for PCIe Gen6 on Agilex-7 FPGAs with FHT and FGT PMAs, here are a few considerations:
Device Support:
Verify that the specific Agilex-7 device you are using supports PCIe Gen6 (64 GT/s) and PAM-4 64 GT/s through the FHT or FGT PMAs. Not all Agilex devices may support this speed in all transceiver configurations.
IP Selection:
Use the correct Intel Transceiver PHY IP. For Agilex-7, ensure you're using the latest version of Quartus Prime Pro, as older versions may not include full support for PCIe Gen6 or PAM-4 64 GT/s capabilities.
- Muneet
Could Please specify which Agilex-7 Device to use for PCIe Gen6 Support?
Currently, I am using 2024.1 version of the Quartus Prime Pro. This is the latest available software on the tool website.
- AR_A_Intel
For PCIe Gen6 support on Agilex-7, the recommended is using devices equipped with F-Tile, specifically those that include FHT PMAs, as these are optimized for high-speed applications like PCIe Gen6.
- AR_A_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
