8 years agoUnable to constrain bidirectional port.
I have a module that is used to control the operation of an I[SUP]2[/SUP]C bus. One of the outputs in the module is a bidirectional SDA line. I've attempted to constrain the design using the SDC comm...
8 years ago --- Quote Start --- I have a module that is used to control the operation of an I[SUP]2[/SUP]C bus. One of the outputs in the module is a bidirectional SDA line. I've attempted to constrain the design using the SDC commands:
set_output_delay -clock i2c_clk -min 0.0
set_output_delay -clock i2c_clk -max 0.0
set_input_delay -clock i2c_clk -max 0.0
set_input_delay -clock i2c_clk -min 0.0 where i2c_clk is created with: create_generated_clock -source -divide_by 126 -name i2c_clk CLOCK_50 is a 50MHz input clock and {i2c:i2c_inst|i2c_clk} comes from the fact that my design instantiates the i2c module in a top level module. The output delay seems to work fine. However, I'm getting errors associated with the input delay: "Warning (332174): Ignored filter at lab03.sdc(22): FGPA_I2C_SDAT could not be matched with a port" and "Warning (332049): Ignored set_input_delay at lab03.sdc(22): Argument <targets> is an empty collection". I thought this may have been an issue because I am specifying both input and output delays on the same port, but when I comment out the output delays I get the same error. Additionally, when I run TimeQuest to see the unconstrained input ports, it gives "FPGA_I2C_SDAT" (i.e. exactly the same as input I'm trying to constrain). I noticed in Ryan Scoville's TimeQuest User Guide on page 114 that internal clocks should not be used to constrain IO ports. However, if I try it with a virtual clock of the same frequency I get the same error. If any of this is unclear let me know and I'll clarify/post more code. Thanks in advance. --- Quote End --- First: I have never seen any examples of bidirectional io sdc in the entire pile of Altera timequest documents or its associates. Second: I suggest you try -add or -add_delay to input set. Third: your observation about input ports not recognized is strange. You know it exists and the tool does as well so somebody in Altera team of software must have a bug or your observation is wrong.
