10 years agoultrasonic sensor in VHDL
hi everyone, i have some problems in testing the following code, by knowing that i found this code in this forums, can anybody test it and tell me if he found the same problems and how to solve it. ...
10 years ago:)thnx for helping me i appreciate that, i will try to modify it and see if i get any result. :)
--- Quote Start --- Its in the Xula repository, and with 30s of searching I found it had a Xilinx chip. What gave it away from your post was the failure to find the UNISIM library - which is a Xilinx primitives simulation library. To get it working for Altera, you'll have to strip out all references to UNISIM. If all you want is this one file - just delete the unisim library. --- Quote End ---
