10 years agoultrasonic sensor in VHDL
hi everyone, i have some problems in testing the following code, by knowing that i found this code in this forums, can anybody test it and tell me if he found the same problems and how to solve it. ...
10 years agoIts in the Xula repository, and with 30s of searching I found it had a Xilinx chip.
What gave it away from your post was the failure to find the UNISIM library - which is a Xilinx primitives simulation library. To get it working for Altera, you'll have to strip out all references to UNISIM. If all you want is this one file - just delete the unisim library.
