EBoln
5 years agoUbuntu usb blaster
I have: Quartus Std 18.1.1 and Quartus Std 20.1 on Windows 10, 11 and Ubuntu 18.04 and 20.04
Everything works on Windows, but on Ubuntu none of the options.
There is a project, build on all...
Nurina
5 years agoHi,
Do you receive any error messages when you try to launch SignalTap?
Nurina
- EBoln5 years ago
Yes: instance not found, but sof not programmed....
- Nurina5 years ago
Here's an old thread with a similar problem: https://community.intel.com/t5/Intel-Quartus-Prime-Software/Signal-Tap-Instance-not-found/td-p/1293277
Could you try following the steps done and let me know if it helped?
Nurina
- EBoln5 years ago
I tried to sew the same file from windows that from linux
I would say that this topic is similar, but there is no solution:
