12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years agoYes, it is. You have separated out all of your combinatorial logic into one process, and then registered it in another.
Aslong as they are placed in a clocked process that uses the correct clock, then its fine.
