12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years ago --- Quote Start --- Hi tricky, I am doing this already, for example, in the line 110 from the rx_uart.vhd:
-- left concatenate the new bit, assuming the bits are sent LSB to MSB
byte_next <= rx & byte_reg(7 downto 1); --- Quote End --- THis assumes that the rx input is already synchronised which it isnt. You need the double register BEFORE this to ensure you get real values, not a meta stable one inside the byte(0) register. The problem will not be the DCFIFO. THat also requires synchronised inputs.
