12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years agoGod, You told me it a lot and I again forgot to put what is needed inside the sensitive list. I made this correction and
I made the n_mod as a flipflop model like the others signals. It works now, thank you very much Tricky. Code attached.
