12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years agoI'll try to model like others signal in the code. I mean like flip-flops.
If not work maybe putting the '0' or '1' directly in the output pin to try to avoid this issue.
