12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years agoHi friends, I have just a theoretical doubt about rx uart and I would appreciate if any help.
The system clock, provided for the board is 50Mhz, and I was needing a 115200bps UART. I made a mod entity that outputs 1 tick every 13 ticks from the system clock including a 16 oversampling, based on this claculations: 16 is my choice for the number of oversampling for RX bits. 115200bps is the uart baud rate. 50Mhz is the system clock. 50Mhz/(16*115200) = 27,126736111 what I assumed to be 27. So, if 50Mhz system clock has 20 ps in each cicle, after 27*20ps = 540 ps the mod entity would be generate one tick. As soon as the start bit is detected, I am interested in sampling the middle of this bit, so, at 13ª cicle or 540ps/2 = 270 ps after this start bit is being detected. All this explanation is to justify why I made the mod count from 0 to 12 to outputs one tick, for detecting the middle of start bit and after I wait two ticks of 0 to 12, I take the sample for data bits and stop bits. It gives me a conversion from 50Mhz to 1/540ps = 1.851 Hz, what I think it is close to the1.8432Hz needed to 115200bps. I attached the begin and the end of simulation. Are that correct? Thank you very much.
