12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years agoWell, for a start, the RX.vhd has code in parrellel to the clock - this is bad practice, it should be in it's own asynchronous process.
This async code contains a counter - with asynchronous counters you're just putting the code into an infinite loop - as soon as the counter increments, it will increment again over and over in 0 time, hence you will lock up the simulator. If you insist on doing a counter in an asynchronous process, you should produce a count_next signal and then register it in another process. You have an almost identical problem in tx.vhd. Inside a synchronous process, you only need to have the clock and any asynchronous resets in the sensitivity list. A sensitivity list tells the process which signals should cause a re-evaluation of the process. So for a synchronous process, the outputs can only change on a clock edge, so its not worth having other signals in there as nothing will change when they change.
