10 years agoTwo's Complement and Floating Point
Hello, I have a range of integer values coming into my system in a two's complement format (positive and negative values). I run these through the altfp_convert module to make these integers ...
10 years agoThen I suspect the output is always +ve
Is there any reason you're using floating point? it's very costly to implement in terms of logic and latency. Fixed point is much cheaper.
