14 years ago
Two errors: Port "devoe" does not exist | WYSIWYG LCELL COMB primitive
Hi all, I encountered two errors when running quartus ii. I am using modelsim altera edition.
Here is what I did:
Take a verilog file as input, run quartus ii on it and get the verilog output file (.vo) file. I made some changes in .vo file and re-ran quartus two on it. I first changed the extension from .vo to .v, took the stratixiii_atoms.v (from modelsim_altera) as the lib file (use `include). But the quartus ii got two kinds of weired errors when running.
Error one: Port "devoe" does not exist in primitive "stratixiii_io_obuf" of instance "xxx"
Error two: WYSIWYG LCELL COMB primitive "xxx" must use LUT_MASK parameter
In the .v (changed from .vo), the instantiation of stratixiii_io_obuf does have the devoe port as .devoe(devoe). And "defparam xxxxxx.lut_mask = 64'h00FF00FF08F708F7" also presents in the file.
Does anyone has any idea why these things are happening?
Thanks in advance.
L
