8 years agotwentynm_fp_mac_encrypted simulation in questasim
I have some problem with simulaion fpga project with twentynm_fp_mac_encypted component. How can I get HDL code for simulation of this component or find full information about functions of this componet ? Thank you5 Replies
I need to run simulation OpenCL FPGA project of neural network (NN) with float point computations.
Can I generate in Qsys tool HDL code of this NN for simulation ? - Altera_Forum
--- Quote Start --- QuestaSim get this error Module 'twentynm_fp_mac_encrypted' is not define. As per you previous threadhttps://www.alteraforum.com/forum/showthread.php?t=57404 --- Quote End --- Can you edit the msim_setuo.tcl file and check again. 1.Add below lines in Compile device library files section of msim_setuo.tcl
Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)eval vlog $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/twentynm_atoms_ncrypt.v" -work twentynm eval vlog $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/twentynm_hssi_atoms_ncrypt.v" -work twentynm_hssi eval vlog $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/twentynm_hip_atoms_ncrypt.v" -work twentynm_hip - Altera_Forum
--- Quote Start --- Hi, Can you edit the msim_setuo.tcl file and check again. 1.Add below lines in Compile device library files section of msim_setuo.tcl
Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- This is not working. Instantitaion of twentynm_fp_mac_encrypted failed. Design unit is not foundeval vlog $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/twentynm_atoms_ncrypt.v" -work twentynm eval vlog $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/twentynm_hssi_atoms_ncrypt.v" -work twentynm_hssi eval vlog $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/twentynm_hip_atoms_ncrypt.v" -work twentynm_hip - Altera_Forum
Hi ,
Can you share your msim_setuo.tcl file? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Hi ,
You can simulate designs using the encrypted IP but cannot edit them. To simulate the IP, you need to compile the twentyfivenm library. This file can be found in the Quartus intallation directory. C:\IntelFPG\17.1\quartus\eda\sim_lib You can compile the twnetyfivenm VHDL /Verilog files into your work library and then recompile and simulate your design.
