JPrig
5 years agoTTK fails to run on Arria 10
I try to get TTK up and running on a custom Arria 10 design. My FPGA project is very simple. I have a PLL which generates a system clock of 120MHz and a reset synchronized to this clock. I use...
Deshi_Intel
5 years agoHi,
Thanks for sharing Quartus design.
- NativePHY IP setting is fine.
- I can see reconfig_clk and reconfig_reset connection is controlled by your own design "clock_reset_gen.vhd" but I don't see the signal_tap result. Pls share the signal_tap result file with me.
- Other than that, you can look into some of my debug suggestion in my previous post.
dlim
JPrig
5 years agoHi,
thanks for your suggestions. I have discovered that the reconfig_clk and reconfig_reset of the transceiver PLL were not connected. After I have connected them to system clock and reset, the error message disappeared and I am able to detect channels.
Thanks for the help.
Regards, Julia
