13 years agoLibrary IEEE;
use IEEE.STD_LOGIC_SIGNED; use IEEE.STD_LOGIC_UNSIGNED; use ieee.std_logic_1164.all; use IEEE.numeric_std.all; entity ltestinggpiowithdelay is port( GPIO_0 : in std_logic_vector(2 downto 0); CLK : in std_logic; DIN : in std_logic_vector (2 DOWNTO 0); q : out std_logic_vector(2 downto 0)); end ltestinggpiowithdelay ; architecture bufferwithGpio_arc of ltestinggpiowithdelay is begin process(GPIO_0) begin if (GPIO_0(0)='1') then q<=GPIO_0(2 downto 0); else q<= "000"; end if; end process; clk_proc:process(CLK) variable count:std_logic_vector(2 downto 0) := "000"; begin if (CLK'EVENT AND CLK = '1') then if GPIO_0(0) = '1' then count := DIN; else count := "count+1 >"; end if; end if; q <= count after 50 ns; end process clk_proc; end bufferwithGpio_arc; mr daixiwen so my programming is basically to read the input from the PIR sensor and i would like to maintain the output for sometime when the PIR detects movement as to turn on a relay etc. please check whether my programming is correct or not. now when i compile the program it seems a new error stated( object with std_logic type cannot contain character 'C'object with std_logic type cannot contain character 'C').. i am already blank already. please guide me.
