Altera_ForumHonored Contributor12 years agoTrying to on led using the input from pir sensor Hi guys im very new in VHDL and im trying to write a program as to turn on an LED from the GPIO_0 which i put a PIR sensor to it..the PIR sensor is directly connectted to GPIO_O(0).. so the problem ...Show Moremyprogram.jpg234 KB
Recent DiscussionsWhen you double click on a word, the other instances do not highlight due to the Find Box being openjtagserver.exe causing BSOD together with ftdi driverAutomatically added negative node for TDS output doesn't work with Agilex 5Agilex3 - unknown IDCODESignal Tap - *** Fatal Error: Segment Violation
