Altera_ForumHonored Contributor13 years agoTrying to on led using the input from pir sensor Hi guys im very new in VHDL and im trying to write a program as to turn on an LED from the GPIO_0 which i put a PIR sensor to it..the PIR sensor is directly connectted to GPIO_O(0).. so the problem ...Show Moremyprogram.jpg234 KB
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
