Altera_ForumHonored Contributor16 years agotrouble with mif i creat a new mif . but the address is unsigned decimal . how can i change it to hex, so i can enter the data in hex.
Altera_ForumHonored Contributor16 years agoit is a image! i have found how to change the address into hex. thx everybody!
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
