on0308
4 years agoTrouble with "Convert Programming Files..." in Quartus II 13.1.4
Hello
When I generate a .cof file with "Save Conversion Setup..." in "Convert Programming Files...",
the contents of "Advanced options..." are not output.
What is the solution?
By the way, ...
- 4 years ago
Yes, your understanding is correct.
on0308
4 years agoHello
Thank you for your answer.
>the “Advanced options” is not supported in Quartus13.1.4. version.“
That means that in the .cof file,
<cof>
<advanced_options>
<ignore_epcs_id_check>1</ignore_epcs_id_check>
</advanced_options>
</cof>
Even if you add something like that and convert it, the "advanced options" setting will be ignored, right?
Best regards
