8 years agoTrouble using EPCS on Intel (Altera) DE10-standard
I'm using the DE-10 standard Intel FPGA. I'm trying to get a simple program that blinks a single LED to run when the FPGA is booted. From my understanding of the manual, the process involves converti...
8 years agoHi,
I suspect on the .sof used to generate the .jic file, Check if you have selected a correct .sof file while generating .jic? Does programmer shows progress 100% successful while programming .jic? After that, you need to restart the board. Have you tried to Erase the EPCS device and program? Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
