11 years agotrouble generating system and compiling with SOPC builder
Hi, I have been trying to follow the online training for SOPC builder to get the system generated and compiling. I am using the 30 day evaluation license of quartus II (10.0). I created a...
11 years agoHi,
That's a very good explanation. The top level entity name while creating the new project and the top module name should be the same. In case if its not, you can change the top level entity name later on too. go to Assignments--> Settings-- >General and you will see the option top level entity. You can change it here. You will need to instantiate the sopc system in your top level module. Thanks,
