MRodr3
8 years agoTransfer data from pc to fpga through fibra channel
Hello, I am looking for a solution to transfer images from PC to my FPGA board. I am using the Terasic DE5-Net board with a Stratix V FPGA. The board is connected by the USB Blaster cable to the PC...
corestar
Contributor
8 years agoYou don't provide enough detail for anyone to give an informed answer. How big are the images? How fast to you need to transfer? How far?
Does it have to be this board? If so, it has 3 interfaces: RS422, SFP and PCIe.
RS422 is simple but slow. You could use an RS422 to USB cable.
The PCIe is fast but you would have alot of work to do.
I've never used SFP but I suspect it is not simple either.
