11 years agotransceiver toolkit does not detect links
I have two Arria II GX boards connected over a transceiver link. One board is ours and has an eSATA interface. The other board is a Arria II GX dev kit (6Gbps version) with a terasIC SATA/SAS HSMC da...
11 years ago --- Quote Start --- I'm running 13.0 sp1. This is the same version I ran last year when I did this and it worked fine. --- Quote End --- Ok, so your problem might be something else (since it used to work with that version). --- Quote Start --- How do I manually create links? --- Quote End --- On the version I was testing (I forget exactly which - probably 14.0 64-bit) there was a setup button on the TTK GUI, and I had to link the pattern generator + PHY + pattern checker for each lane (I was doing multi-lane setups). I'm in the process of repeating those tests under 14.1, but this time I am documenting what I did so I can more easily repeat the tests :) Cheers, Dave
