11 years agotransceiver toolkit does not detect links
I have two Arria II GX boards connected over a transceiver link. One board is ours and has an eSATA interface. The other board is a Arria II GX dev kit (6Gbps version) with a terasIC SATA/SAS HSMC da...
11 years ago --- Quote Start --- My recollection from last year is that everything just came up and worked without jumping through any hoops. What am I missing? --- Quote End --- Which version of Quartus are you running? I've found cases where the TTK does not work properly in newer versions of Quartus. I had to manually create the links (and then it worked). Cheers, Dave
