KKuhl1
4 years agoTransceiver Toolkit all tests grayed out
I have a design on an Aria 10 board (10AX115N3F40E2SG is the FPGA PN)
It has 4 SerDes blocks each with 4 bidirectional channels.
When I open up the transceiver toolkit from the project the chan...
- 4 years ago
Thanks for the information
So I found the solution in the youtube video. The issue was that the enable capability registers box has to be checked in the Native Phy IP for the toolkit to proper recognize and set up the links to allow the testing to run.
I had been using the Intel Technical Training course "Transceiver Toolkit for Intel® Arria® 10 and Cyclone® 10 GX Devices" as a reference for how to set up the IP and it incorrectly shows and does not mention that the capability register box needs to be checked.
https://www.intel.com/content/www/us/en/programmable/support/training/course/otcvrkita10.html
Thanks again and problem solved
Deshi_Intel
4 years agoGood. I am glad that your issue is resolved !
