tracking and solve the slack problem when immigrate from std to pro
- 4 years ago
Hi Sstrel,
If I manually open one of the IP in the list. it will fail because "component dec_data_capture 1.0 not found or could not be instantiated".
I confirmed the file is there in the first line listed directory. I don't know why it couldn't be instantiated.
but the overall project can compile without any problem.
What steps did you take to migrate from std to pro? You need to make changes to your qsf file, sdc and tcl scripts and maybe even RTL code for a successful migration. Refer to this video training on migrating to the Intel Quartus Prime Pro: https://www.youtube.com/watch?v=P_6gemOLtjE
Even though your timing has closed in Standard edition, it might fail in Pro edition. This is because the timing algorithm is different, so you may have to take different/more steps to close timing with the same project. The same applies to when you migrate to a different version of Quartus.
Nurina
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
