tracking and solve the slack problem when immigrate from std to pro
- 4 years ago
Hi Sstrel,
If I manually open one of the IP in the list. it will fail because "component dec_data_capture 1.0 not found or could not be instantiated".
I confirmed the file is there in the first line listed directory. I don't know why it couldn't be instantiated.
but the overall project can compile without any problem.
If all the IP are in Platform Designer, you can just regenerate the system there or select Upgrade IP Cores from the System menu if it's available.
If the IP are not in a PD system, you can do the same from Quartus: Project menu -> Upgrade IP Components.
Hi Sstrell,
I posted the Quartus IP upgrade page.
it says All (40) IPs. there are none of them Must upgrade.
and in the list, the versions are different. some of them for example is 21.3, some are 19.1.0. should I manually upgrade all none 21.3 version IP to the latest?
Thanks for help
David
