dsun01
Contributor
4 years agotracking and solve the slack problem when immigrate from std to pro
Dear Quartus Support/Expert,
I guess this is a very entry level question. I hope some experienced user can answer easily.
I have a TI dev kit, which is in STD version 14, and the device is 10AX1...
- 4 years ago
Hi Sstrel,
If I manually open one of the IP in the list. it will fail because "component dec_data_capture 1.0 not found or could not be instantiated".
I confirmed the file is there in the first line listed directory. I don't know why it couldn't be instantiated.
but the overall project can compile without any problem.
sstrell
4 years agoIf all the IP are in Platform Designer, you can just regenerate the system there or select Upgrade IP Cores from the System menu if it's available.
If the IP are not in a PD system, you can do the same from Quartus: Project menu -> Upgrade IP Components.
dsun01
Contributor
4 years ago
